De volgende waarschuwingen zijn opgetreden:
File Line Function
/inc/class_error.php 153 errorHandler->error
/inc/plugins/gomobile.php 201 errorHandler->error_callback
/inc/class_plugins.php 142 gomobile_forcetheme
/global.php 100 pluginSystem->run_hooks
/showthread.php 28 require_once
Warning [2] Undefined array key "gomobile" - Line: 214 - File: inc/plugins/gomobile.php PHP 8.3.20 (Linux)
File Line Function
/inc/plugins/gomobile.php 214 errorHandler->error_callback
Warning [2] Undefined array key "gomobile" - Line: 275 - File: inc/plugins/gomobile.php PHP 8.3.20 (Linux)
File Line Function
/inc/plugins/gomobile.php 275 errorHandler->error_callback
Warning [2] Undefined array key "style" - Line: 280 - File: inc/plugins/gomobile.php PHP 8.3.20 (Linux)
File Line Function
/inc/plugins/gomobile.php 280 errorHandler->error_callback
Warning [2] Undefined property: MyLanguage::$today_rel - Line: 476 - File: inc/functions.php PHP 8.3.20 (Linux)
File Line Function
/inc/functions.php 476 errorHandler->error_callback
/global.php 490 my_date
Warning [2] Undefined array key "oa_social_login_custom_caption" - Line: 356 - File: inc/plugins/oa_social_login.php PHP 8.3.20 (Linux)
File Line Function
/inc/plugins/oa_social_login.php 356 errorHandler->error_callback
/inc/plugins/oa_social_login.php 197 oa_social_login_load_plugin
/inc/class_plugins.php 142 oa_social_login_load_plugin_hook_any
/global.php 498 pluginSystem->run_hooks
Warning [2] Undefined property: MyLanguage::$bottomlinks_forumteam - Line: 2 - File: global.php(1047) : eval()'d code PHP 8.3.20 (Linux)
File Line Function
/global.php(1047) : eval()'d code 2 errorHandler->error_callback
/global.php 1047 eval
Warning [2] Undefined array key "style" - Line: 298 - File: inc/plugins/gomobile.php PHP 8.3.20 (Linux)
File Line Function
/inc/plugins/gomobile.php 298 errorHandler->error_callback
/inc/class_plugins.php 142 gomobile_forcefooter
/global.php 1276 pluginSystem->run_hooks
Warning [2] Undefined property: MyLanguage::$ratings_update_error - Line: 5 - File: showthread.php(799) : eval()'d code PHP 8.3.20 (Linux)
File Line Function
/showthread.php(799) : eval()'d code 5 errorHandler->error_callback
/showthread.php 799 eval
Warning [2] Undefined property: MyLanguage::$post_deleted_error - Line: 21 - File: showthread.php(1650) : eval()'d code PHP 8.3.20 (Linux)
File Line Function
/showthread.php(1650) : eval()'d code 21 errorHandler->error_callback
/showthread.php 1650 eval
Warning [2] Undefined property: MyLanguage::$tyl_send - Line: 38 - File: showthread.php(1650) : eval()'d code PHP 8.3.20 (Linux)
File Line Function
/showthread.php(1650) : eval()'d code 38 errorHandler->error_callback
Warning [2] Undefined property: MyLanguage::$tyl_remove - Line: 39 - File: showthread.php(1650) : eval()'d code PHP 8.3.20 (Linux)
File Line Function
/showthread.php(1650) : eval()'d code 39 errorHandler->error_callback
stuurhuis lekt een beetje, direct vervangen of niet?
Het stuurhuis van mijn 74-er is een beetje lek. Bij de koop zit een vervangend stuurhuis.
* een beetje lek: als de keef een nachtje gestaan heeft liggen er wat zwarte oliedruppels
Twee vragen;
- is het vervangen erg moeilijk? En zijn er zaken waar ik op moet letten? En of/ alvast nieuw moet kopen? (ik denk dan aan pakkingen, rubbers etc.)
- is het schadelijk om nog even door te rijden of kan dat niet direct kwaad?
Is het zeker je stuurhuis?
Hangt er ook "olie" aan het stuurhuis?
En om je gerust te stellen nee is niet levens bedreigend zolang je stuurhuis goed werkt.
In je stuurhuis zit eigenlijk een soort van vet. maar door ouderdom gaat dit vet vocht verliezen en dat komt er dan al een soort van olie uit gedrupt.
Vervangen is wel even wat werk maar met het juiste gereedschap is dit wel te doen.
Hou er wel rekening mee dat na vervanging je stuur wat scheef kan staan en je kever zelfs even beter opnieuw uitgelijnd moet worden.
Als je er aan begin dan wil ik je wel wat meer vertellen hoe en wat maar daar heb ik nu even geen tijd voor.
Dat kan ik nog niet met zekerheid zeggen, want ik heb de kever nog niet thuis  Dodgy
Ik was wat voorbarig met mijn vraag misschien, maar de vorige eigenaar heeft er een extra stuurhuis bij en vertelde waarom. En er lag wat olie onder de auto.
Er zat een druppel aan het stuurhuis.
Ik weet meer als hij hier thuis is. Dan zal ik de plannen daarop baseren.
In ieder geval goed om vooraf te weten waar ik aan toe ben. Dankjewel!!  Idea
Anders even wat foto’s plaatsen als je m thuis hebt. Foto’s plaatsen is heel makkelijk, direct vanaf je device. Je hoeft de foto’s dus niet eerst ergens apart up te loaden, gewoon ‘add image to post’ onder je bericht aanklikken.
Ah, ok!
Dat is een mooie en handige toevoeging.
Ik zal het doen  Idea
We wachten met spanning af  Big Grin Sowieso beter advies geven dan!
