De volgende waarschuwingen zijn opgetreden:
File Line Function
/inc/class_error.php 153 errorHandler->error
/inc/plugins/gomobile.php 201 errorHandler->error_callback
/inc/class_plugins.php 142 gomobile_forcetheme
/global.php 100 pluginSystem->run_hooks
/showthread.php 28 require_once
Warning [2] Undefined array key "gomobile" - Line: 214 - File: inc/plugins/gomobile.php PHP 8.3.20 (Linux)
File Line Function
/inc/plugins/gomobile.php 214 errorHandler->error_callback
Warning [2] Undefined array key "gomobile" - Line: 275 - File: inc/plugins/gomobile.php PHP 8.3.20 (Linux)
File Line Function
/inc/plugins/gomobile.php 275 errorHandler->error_callback
Warning [2] Undefined array key "style" - Line: 280 - File: inc/plugins/gomobile.php PHP 8.3.20 (Linux)
File Line Function
/inc/plugins/gomobile.php 280 errorHandler->error_callback
Warning [2] Undefined property: MyLanguage::$today_rel - Line: 476 - File: inc/functions.php PHP 8.3.20 (Linux)
File Line Function
/inc/functions.php 476 errorHandler->error_callback
/global.php 490 my_date
Warning [2] Undefined array key "oa_social_login_custom_caption" - Line: 356 - File: inc/plugins/oa_social_login.php PHP 8.3.20 (Linux)
File Line Function
/inc/plugins/oa_social_login.php 356 errorHandler->error_callback
/inc/plugins/oa_social_login.php 197 oa_social_login_load_plugin
/inc/class_plugins.php 142 oa_social_login_load_plugin_hook_any
/global.php 498 pluginSystem->run_hooks
Warning [2] Undefined property: MyLanguage::$bottomlinks_forumteam - Line: 2 - File: global.php(1047) : eval()'d code PHP 8.3.20 (Linux)
File Line Function
/global.php(1047) : eval()'d code 2 errorHandler->error_callback
/global.php 1047 eval
Warning [2] Undefined array key "style" - Line: 298 - File: inc/plugins/gomobile.php PHP 8.3.20 (Linux)
File Line Function
/inc/plugins/gomobile.php 298 errorHandler->error_callback
/inc/class_plugins.php 142 gomobile_forcefooter
/global.php 1276 pluginSystem->run_hooks
Warning [2] Undefined property: MyLanguage::$ratings_update_error - Line: 5 - File: showthread.php(799) : eval()'d code PHP 8.3.20 (Linux)
File Line Function
/showthread.php(799) : eval()'d code 5 errorHandler->error_callback
/showthread.php 799 eval
Warning [2] Undefined property: MyLanguage::$post_deleted_error - Line: 21 - File: showthread.php(1650) : eval()'d code PHP 8.3.20 (Linux)
File Line Function
/showthread.php(1650) : eval()'d code 21 errorHandler->error_callback
/showthread.php 1650 eval
Warning [2] Undefined property: MyLanguage::$tyl_send - Line: 38 - File: showthread.php(1650) : eval()'d code PHP 8.3.20 (Linux)
File Line Function
/showthread.php(1650) : eval()'d code 38 errorHandler->error_callback
Warning [2] Undefined property: MyLanguage::$tyl_remove - Line: 39 - File: showthread.php(1650) : eval()'d code PHP 8.3.20 (Linux)
File Line Function
/showthread.php(1650) : eval()'d code 39 errorHandler->error_callback
Waarschuwingslampje olie
Het waarschuwingslampje van de olie werkt niet meer als je de auto op contact zet. Nu heb ik er reeds een nieuwe oliedruk sensor ingezet, getest of er uberhaupt druk vanuit het blok was (een grote bende, maar druk is er zeker Big Grin ), voorin een nieuw lampje in de teller en een nieuwe zekering.
Iemand nog andere tips of ervaringen met hoe te controleren of de bekabeling nog goed is?
[Afbeelding: IMG-7035.jpg]
Aangezien de teller er toch uit was de rest van de lampjes ook vernieuwd, deze functioneren allemaal wel.
Doet je laadstroomlampje en knipperlichtlampje het nog wel?
Nee? dan krijgen ze geen +12volt spanning via dat centrale contact onder deze drie lampjes.
Deze drie lampjes werken precies andersom tov de andere controle lampjes.
Alle overige krijgen een + spanning op het midden contact en dan massa via de snelheidsmeter behuizing.
de onderste drie lampjes Oliedruk knipperlicht en laadstroom krijgen via de lamphouder permanent +12volt en dan via het midden contact van jet lamphoudertje wordt de massa ingeschakeld.
controle van het olie druk lampje. contact aan!
Staat er +12 volt op de buitenkant van de lamphouder tov een goed massa punt? Ja ? oke dan verder.
Leg een tijdelijke  draad van af het midden contact van de lamphouder naar een goed massa punt.  dan moet het lampje branden. Zo niet dan is of de lamp of de houder defect
Verwijder die tijdelijk draad van het midden contact en sluit de juiste draad aan op de lamphouder.  Hou nu achter bij de motor de draad van de oliedruksensor tegen en goed massapunt.
Gaat het lampje branden? Dan is de draad oke
Hou een controle lampje of spanningsmeter tegen een +12volt punt aan (bv de aansluiting op het relais op jet carburateur) en dan de andere kant van het lampje op de oliedruk schakelaar. Brand het lampje dan niet dan is de schakelaar toch defect!
Op deze manier heb je alle mogelijk oorzaken geprobeerd en uitgesloten!
Succes met zoeken
Al wat wijzer geworden?
