De volgende waarschuwingen zijn opgetreden:
File Line Function
/inc/class_error.php 153 errorHandler->error
/inc/plugins/gomobile.php 201 errorHandler->error_callback
/inc/class_plugins.php 142 gomobile_forcetheme
/global.php 100 pluginSystem->run_hooks
/showthread.php 28 require_once
Warning [2] Undefined array key "gomobile" - Line: 214 - File: inc/plugins/gomobile.php PHP 8.3.20 (Linux)
File Line Function
/inc/plugins/gomobile.php 214 errorHandler->error_callback
Warning [2] Undefined array key "gomobile" - Line: 275 - File: inc/plugins/gomobile.php PHP 8.3.20 (Linux)
File Line Function
/inc/plugins/gomobile.php 275 errorHandler->error_callback
Warning [2] Undefined array key "style" - Line: 280 - File: inc/plugins/gomobile.php PHP 8.3.20 (Linux)
File Line Function
/inc/plugins/gomobile.php 280 errorHandler->error_callback
Warning [2] Undefined property: MyLanguage::$today_rel - Line: 476 - File: inc/functions.php PHP 8.3.20 (Linux)
File Line Function
/inc/functions.php 476 errorHandler->error_callback
/global.php 490 my_date
Warning [2] Undefined array key "oa_social_login_custom_caption" - Line: 356 - File: inc/plugins/oa_social_login.php PHP 8.3.20 (Linux)
File Line Function
/inc/plugins/oa_social_login.php 356 errorHandler->error_callback
/inc/plugins/oa_social_login.php 197 oa_social_login_load_plugin
/inc/class_plugins.php 142 oa_social_login_load_plugin_hook_any
/global.php 498 pluginSystem->run_hooks
Warning [2] Undefined property: MyLanguage::$bottomlinks_forumteam - Line: 2 - File: global.php(1047) : eval()'d code PHP 8.3.20 (Linux)
File Line Function
/global.php(1047) : eval()'d code 2 errorHandler->error_callback
/global.php 1047 eval
Warning [2] Undefined array key "style" - Line: 298 - File: inc/plugins/gomobile.php PHP 8.3.20 (Linux)
File Line Function
/inc/plugins/gomobile.php 298 errorHandler->error_callback
/inc/class_plugins.php 142 gomobile_forcefooter
/global.php 1276 pluginSystem->run_hooks
Warning [2] Undefined property: MyLanguage::$ratings_update_error - Line: 5 - File: showthread.php(799) : eval()'d code PHP 8.3.20 (Linux)
File Line Function
/showthread.php(799) : eval()'d code 5 errorHandler->error_callback
/showthread.php 799 eval
Warning [2] Undefined property: MyLanguage::$post_deleted_error - Line: 21 - File: showthread.php(1650) : eval()'d code PHP 8.3.20 (Linux)
File Line Function
/showthread.php(1650) : eval()'d code 21 errorHandler->error_callback
/showthread.php 1650 eval
Warning [2] Undefined property: MyLanguage::$tyl_send - Line: 38 - File: showthread.php(1650) : eval()'d code PHP 8.3.20 (Linux)
File Line Function
/showthread.php(1650) : eval()'d code 38 errorHandler->error_callback
Warning [2] Undefined property: MyLanguage::$tyl_remove - Line: 39 - File: showthread.php(1650) : eval()'d code PHP 8.3.20 (Linux)
File Line Function
/showthread.php(1650) : eval()'d code 39 errorHandler->error_callback
Uitgebouwd blok starten
Graag zou ik willen weten welke kabels ik waar aan moet sluiten om mijn uitgebouwde keverblok te kunnen starten.
Al vast bedankt voor de reactie.
In principe carburateur, bobine incl draad naar ontsteking en startmotor. Eventueel de dynamo als je het laadsysteem ook wil testen en de oliedruksensor als je zeker wil weten of je oliedruk hebt. De laatste twee zijn niet per se noodzakelijk om hem te laten draaien, maar wel verstandig om te doen.
En uiteraard de benzineslang Big Grin
inderdaad, alleen stroom (ontsteking & startmotor) en benzine zijn echt nodig
En stoom naar het ventiel en verwarmingselement op de carburateur!
Uitgaande van een standaard origineel blokje.
en dan heb je nog iets nodig om de startmotor te monteren!! deze kan niet direct op het vliegwiel gemonteerd worden.
Meestal wordt hier en oud versnellingsbak voor gebruikt zodat de startmotor op het vliegwielhuis gezet kan worden.
Is de carburateur ook noodzakelijk?
Je kan toch ook handmatig de choke bedienen?
Haha zou zeggen probeer het Exclamation
Nee eerlijk. "denk" niet dat het blokje zal starten.
Links op de carburateur zit het afslagventiel. als deze geen 12volt krijgt val je motor niet aanslaan.
En de choke bij en kever werkt andersom dan gewoon.
Bij koude motor staat de choke er altijd op. (klep in carb dicht)
Zodra je de motor wilt starten komt er spanning op het choke element en daar gaat dan een bimetaal aan het werk.
door die spanning wordt dat bimetaal warm en opent de choke klep.
Dus choke klep met de hand er op zetten gaat niet lukken.  afslagventiel
Ah, ok!
Zal het dan toch maar even aansluiten  Blush
Dat zal ook een ook een hoop gevloek schelen: "Grrvvrr .. waarom start dat kl... ding nou niet!"  Angry
