De volgende waarschuwingen zijn opgetreden:
File Line Function
/inc/class_error.php 153 errorHandler->error
/inc/plugins/gomobile.php 201 errorHandler->error_callback
/inc/class_plugins.php 142 gomobile_forcetheme
/global.php 100 pluginSystem->run_hooks
/showthread.php 28 require_once
Warning [2] Undefined array key "gomobile" - Line: 214 - File: inc/plugins/gomobile.php PHP 8.3.20 (Linux)
File Line Function
/inc/plugins/gomobile.php 214 errorHandler->error_callback
Warning [2] Undefined array key "gomobile" - Line: 275 - File: inc/plugins/gomobile.php PHP 8.3.20 (Linux)
File Line Function
/inc/plugins/gomobile.php 275 errorHandler->error_callback
Warning [2] Undefined array key "style" - Line: 280 - File: inc/plugins/gomobile.php PHP 8.3.20 (Linux)
File Line Function
/inc/plugins/gomobile.php 280 errorHandler->error_callback
Warning [2] Undefined property: MyLanguage::$today_rel - Line: 476 - File: inc/functions.php PHP 8.3.20 (Linux)
File Line Function
/inc/functions.php 476 errorHandler->error_callback
/global.php 490 my_date
Warning [2] Undefined array key "oa_social_login_custom_caption" - Line: 356 - File: inc/plugins/oa_social_login.php PHP 8.3.20 (Linux)
File Line Function
/inc/plugins/oa_social_login.php 356 errorHandler->error_callback
/inc/plugins/oa_social_login.php 197 oa_social_login_load_plugin
/inc/class_plugins.php 142 oa_social_login_load_plugin_hook_any
/global.php 498 pluginSystem->run_hooks
Warning [2] Undefined property: MyLanguage::$bottomlinks_forumteam - Line: 2 - File: global.php(1047) : eval()'d code PHP 8.3.20 (Linux)
File Line Function
/global.php(1047) : eval()'d code 2 errorHandler->error_callback
/global.php 1047 eval
Warning [2] Undefined array key "style" - Line: 298 - File: inc/plugins/gomobile.php PHP 8.3.20 (Linux)
File Line Function
/inc/plugins/gomobile.php 298 errorHandler->error_callback
/inc/class_plugins.php 142 gomobile_forcefooter
/global.php 1276 pluginSystem->run_hooks
Warning [2] Undefined property: MyLanguage::$ratings_update_error - Line: 5 - File: showthread.php(799) : eval()'d code PHP 8.3.20 (Linux)
File Line Function
/showthread.php(799) : eval()'d code 5 errorHandler->error_callback
/showthread.php 799 eval
Warning [2] Undefined property: MyLanguage::$post_deleted_error - Line: 21 - File: showthread.php(1650) : eval()'d code PHP 8.3.20 (Linux)
File Line Function
/showthread.php(1650) : eval()'d code 21 errorHandler->error_callback
/showthread.php 1650 eval
Warning [2] Undefined property: MyLanguage::$tyl_send - Line: 38 - File: showthread.php(1650) : eval()'d code PHP 8.3.20 (Linux)
File Line Function
/showthread.php(1650) : eval()'d code 38 errorHandler->error_callback
Warning [2] Undefined property: MyLanguage::$tyl_remove - Line: 39 - File: showthread.php(1650) : eval()'d code PHP 8.3.20 (Linux)
File Line Function
/showthread.php(1650) : eval()'d code 39 errorHandler->error_callback
j&s safeguard vampire (knock control system)
bescherm u dure opgevoerde motor !
geen sensor aanwezig, deze is zo te koop
prijs 300€
[Afbeelding: 20201011-193515.jpg]
[Afbeelding: 20201011-193530.jpg]
info:
SafeGuard retards timing if knock is detected, protecting your engine from destructive detonation.
The control system retards only the knocking cylinders, maximizing power while protecting the engine.
The system also features boost retard and nitrous or switched retard.
The boost retard section includes Start and Rate controls, allowing you to tailor the retard curve to your needs.
Switched retard could be enabled by a nitrous switch or a manual toggle switch, in case you fill up with low octane fuel.
