De volgende waarschuwingen zijn opgetreden:
File Line Function
/inc/class_error.php 153 errorHandler->error
/inc/plugins/gomobile.php 201 errorHandler->error_callback
/inc/class_plugins.php 142 gomobile_forcetheme
/global.php 100 pluginSystem->run_hooks
/showthread.php 28 require_once
Warning [2] Undefined array key "gomobile" - Line: 214 - File: inc/plugins/gomobile.php PHP 8.3.20 (Linux)
File Line Function
/inc/plugins/gomobile.php 214 errorHandler->error_callback
Warning [2] Undefined array key "gomobile" - Line: 275 - File: inc/plugins/gomobile.php PHP 8.3.20 (Linux)
File Line Function
/inc/plugins/gomobile.php 275 errorHandler->error_callback
Warning [2] Undefined array key "style" - Line: 280 - File: inc/plugins/gomobile.php PHP 8.3.20 (Linux)
File Line Function
/inc/plugins/gomobile.php 280 errorHandler->error_callback
Warning [2] Undefined property: MyLanguage::$today_rel - Line: 476 - File: inc/functions.php PHP 8.3.20 (Linux)
File Line Function
/inc/functions.php 476 errorHandler->error_callback
/global.php 490 my_date
Warning [2] Undefined array key "oa_social_login_custom_caption" - Line: 356 - File: inc/plugins/oa_social_login.php PHP 8.3.20 (Linux)
File Line Function
/inc/plugins/oa_social_login.php 356 errorHandler->error_callback
/inc/plugins/oa_social_login.php 197 oa_social_login_load_plugin
/inc/class_plugins.php 142 oa_social_login_load_plugin_hook_any
/global.php 498 pluginSystem->run_hooks
Warning [2] Undefined property: MyLanguage::$bottomlinks_forumteam - Line: 2 - File: global.php(1047) : eval()'d code PHP 8.3.20 (Linux)
File Line Function
/global.php(1047) : eval()'d code 2 errorHandler->error_callback
/global.php 1047 eval
Warning [2] Undefined array key "style" - Line: 298 - File: inc/plugins/gomobile.php PHP 8.3.20 (Linux)
File Line Function
/inc/plugins/gomobile.php 298 errorHandler->error_callback
/inc/class_plugins.php 142 gomobile_forcefooter
/global.php 1276 pluginSystem->run_hooks
Warning [2] Undefined property: MyLanguage::$ratings_update_error - Line: 5 - File: showthread.php(799) : eval()'d code PHP 8.3.20 (Linux)
File Line Function
/showthread.php(799) : eval()'d code 5 errorHandler->error_callback
/showthread.php 799 eval
Warning [2] Undefined property: MyLanguage::$post_deleted_error - Line: 21 - File: showthread.php(1650) : eval()'d code PHP 8.3.20 (Linux)
File Line Function
/showthread.php(1650) : eval()'d code 21 errorHandler->error_callback
/showthread.php 1650 eval
Warning [2] Undefined property: MyLanguage::$tyl_send - Line: 38 - File: showthread.php(1650) : eval()'d code PHP 8.3.20 (Linux)
File Line Function
/showthread.php(1650) : eval()'d code 38 errorHandler->error_callback
Warning [2] Undefined property: MyLanguage::$tyl_remove - Line: 39 - File: showthread.php(1650) : eval()'d code PHP 8.3.20 (Linux)
File Line Function
/showthread.php(1650) : eval()'d code 39 errorHandler->error_callback
Koelsleuf onder kentekenverlichting
Hallo mede-liefhebbers,
Onder de kentekenverlichting van mijn 1303 LS cabriolet bevindt zich een rechthoekige sleuf die daar kennelijk is aangebracht om extra koeling te geven aan de motor.
Voordat ik mijn kever liet restaureren, zat er op de plek van de sleuf een soort lamellen-ding (hoe leg ik dit goed uit?) die deze sleuf afsloot. Deze lamellen werden door de warmte vanzelf geopend.
Nadat mijn kever door een gespecialiseerd bedrijf is gerestaureerd, is dit onderdeeltje zoekgeraakt.
Ik heb overal gezocht, maar kan dit nergens meer vinden.
Op dit moment kijk je, vanaf de onderzijde van de kentekenverlichting, rechtstreeks de motorruimte in.
Nu kan ik er natuurlijk iets van gaas op monteren, maar het liefst zou ik dat lamellen-systeempje weer terug hebben.
Is dit uberhaupt een origineel onderdeel geweest van een 1303 of is dit een aftermarket-onderdeel geweest?
En het belangrijkste: weet iemand of dit nog te koop is?
Alvast dank voor de reactie!
Vriendelijke groet,
Johan
